I created this thread that centralize all the components to keep when I want to use a functionality or a program in Windows 7.
It's for people (like me) who searched for many times a solution.
=> VERSION 4.00 (FINAL)
*** Minimum Requirements ***
. RT 7 1.7.0+ (Thanks Bensam !!!!!)
. WINDOWS 7 x86 (or x64) with SP1 RTM
=> SUMMARY =
. I – All LastSessions
. II - Components you should never delete
. III - Components you should keep for your needs
. IV - Components you should keep for your software
. V - Post Changes
I – "Advanced LASTSESSION" by WinterStorm2050
It works for Audio, Aero Theme, Ethernet, Games, Internet, Music, Video, Printers, Scanners ...
. ISO size = 1.30 Go. (MSDN Win7 SP1 = 1.00 Go.)
. Installation size = 3.20 Go (without Paging File and Hibernate).
. Memory Usage = 500 Mo (Approximatively)
==> Many troubles : like errors in Eventlog and Application Experience (Authorization File Locked) have been resolved if you clean your ISO with RT7-Booster v5.00+
FOR BEGINNERS:
PLEASE READ THIS FIRST : LINK
For those who don't have an already created Lastsession.inf :
Move Lastsession.inf in : "C:\Program Files\Rockers Team\RT7 Lite\Preset"
In RT Seven Lite => Configure it for your needs especially for Drivers Section !!!!!
==> FIND ALL FILES HERE =
Advanced Lastsession
https://rapidshare.com/files/1360795766/Lastsession_Advanced.zip
VMware Lastsession
https://rapidshare.com/files/282935806/Lastsession_VMware.zip
Virtualbox Lastsession
Uploading ... Please wait ....
II - NEVER DELETE THESE COMPONENTS
(THEY ARE REQUIRED OTHERWISE WINDOWS SETUP CRASHES)
==> NEED MANY MORE TEST <==
* DRIVERS =
- Standard VGA Graphics Adapter (Choose driver for your hardware)
- Storage Controllers (Choose driver for your hardware)
- ACPI
- USB
* SERVICES =
- Application Experience (Breaks some locked authorization files)
- Background Intelligent Transfer Service (Breaks Windows Setup)
- Base Filtering Engine (If remove, your CPU raise to 100%)
- Com+ Event System (Breaks Logon and Logoff Windows Session)
- Com+ System Application
- DCOM Server Process Launcher (Many services depend on it)
- Plug and Play
- Power
- Remote Procedure Call (RPC) (Many services depend on it)
- RPC Endpoint Mapper (Breaks Remote Procedure Call (RPC))
- System Event Notification Service
- Thread Ordering Server (Avoid slowing down OS)
- User Profile Service (Breaks Logon and Logoff Windows Session)
- Virtual Disk (Breaks Support for HDD Service under Microsoft Common Console)
- Windows Driver Foundation – User-mode Driver Framework (Avoid slowing down OS)
- Windows Event Collector (Breaks Windows Event Log)
- Windows Event Log
- Windows Font Cache Service (Avoid slowing down OS)
- Windows Management Instrumentation
- Windows Module Installer (Breaks many software installation)
- Windows Presentation Foundation Font Cache 3.0.0.0
* SYSTEM =
- System Properties (Breaks Windows Explorer System Properties)
- User Account Control (For OS Security Reason but Windows 7 works without)
- Windows Script Host (Seems to break RT 7 Lite 2.6.0 when processing components remove)
III - COMPONENTS YOU SHOULD KEEP FOR YOUR NEEDS
Take care about Audio, Network, Software Installation and Windows Update :
because without them you loose some Windows 7 Functionnalties like Internet,
Sounds, Softwares or Games cannot install and Windows Update won't work.
You could Try to add or remove :
-> Components with a + before the name: you could add it in my list
-> Components with a – before: you could remove it from my list
-> Components with a +- before: some parts are already present in my list
- AERO THEMES
- Accessories =>
. Aero Cursors
- Multimedia =>
. Windows Aero Themes
. Windows Wallpapers
- Services =>
. Desktop Window Manager Session Manager
. Windows Search (Keep Windows Search Default Features)
- AUDIO = (NOT SAFE TO REMOVE)
- Drivers => Media Manager => Audio =>
. High Definition Driver (Default)
. Microsoft Audio Home Theater (May works without but depends on your hardware : Link to Post)
. WDM Audio Drivers
. Microsoft Media Manager
- Drivers => System =>
. High Definition Audio Bus Driver
- Services =>
. Windows Audio
. Windows Audio Endpoint Builder
. Multimedia Class Scheduler
. Quality Windows Audio Video Experience
+ AUTOPLAY (Keep it if you use WMP or MCE)
- Multimedia =>
. Auto-Play
- Services =>
. Portable Device Enumerator
. Shell Hardware Detection
- System =>
. Windows Portable Device
+- BACKUP
- Services =>
. Block Level Backup Engine Service (Breaks Volume Shadow Copy)
. Microsoft Software Shadow Copy Provider (Breaks Volume Shadow Copy)
. Volume Shadow Copy
. Windows Backup (Windows works great without, but backup is not usable)
- System =>
. Recovery
. System Restore
+ CREDENTIALS MANAGER (This keeps the shortcut in Control Panel)
- Services =>
. Credentials Manager
- System =>
. SQL Client Configuration Utility
+ COMPUTER BROWSER
- Services =>
. Computer Browser
. Workstation
- DIAGNOSTIC
- Services =>
. Diagnostic Policy Service
. Diagnostic Service Host
. Diagnostic System Host
+ ENCRYPTING STORAGE (Hardware)
- Services =>
. BitLocker Drive Encryption Service
. TPM Base Services
- ENCRYPTING (Software)
- Services =>
. Encrypting File Support
. Protected Storage
. Security Accounts Manager (Get "Sharing tab" disappeared)
+- GROUP POLICY
- Services =>
. Application Management (Windows work great without)
. Group Policy Client
+ FAX
- Accessories =>
. Windows Fax and Scanner
- Drivers =>
. Fax
- Services =>
. Fax
+ HOMEGROUP (Keep it if you use WMP or MCE)
- Services =>
. Function Discovery Resource Publication
. HomeGroup Listener
. HomeGroup Provider
- INTERNET EXPLORER 8 (Keep Internet Explorer 8 Default Features)
- Network ->
. Internet Explorer 8
- Services ->
. Cryptographic Services
- IPsec STRATEGY (Security) (NOT SAFE TO REMOVE) (For IPv6 and IPv4)
- Services =>
. Base Filtering Engine (If remove, your CPU raise to 100%)
. IKE and AuthIP Keyring Modules
. IPsec Policy Agent
- KEYBOARD (Multimedia Keys)
- Services =>
. Human Interface Device Access
- NETWORK = (NOT SAFE TO REMOVE)
- Network=>
. Network Explorer and Sharing Center
- Services =>
. DHCP Client
. Link-Layer Topology Discovery Mapper (Breaks Displays the Entire Network in Network and Sharing Center)
. Network Connections
. Network List Service
. Network Location Awareness
. Network Store Interface Service
And choose what kind of connection you need =
- ETHERNET:
- Drivers => Network =>
. AIO Network Driver (Global Driver)
. Choose driver for your hardware
+ MODEM:
- Drivers => Modem =>
. (Choose driver for your hardware)
- Services =>
. Telephony
+ WIFI:
- Services =>
. CNG Key Isolation
. Extensible Authentication Protocol
. Health Key and Certificate Management
. Network Access Protection Agent
. Windows Connect Now
. WLAN AutoConfig
(. CNG Key Isolation [Keep for Wired AutoConfig ?])
(.EAP Host [Keep for WIFI ?])
+ PEER (From Microsoft)
- Services =>
. BranchCache
. Net.Tcp Port Sharing Service
. Peer Name Resolution Protocol
. Peer Networking Grouping
. Peer Networking Identity Manager
. PNRP Machine Name Publication Service
- PRINTERS and SCANNERS (Keep “Print and Document Service” Default Features)
- PRINTERS:
- Drivers => Printers =>
- Services =>
. Print Spooler
. Server (Breaks Printers Support)
- SCANNERS:
- Drivers => Scanner =>
. Microsoft (Breaks Scanners Support)
- Multimedia =>
. Windows Picture Acquisition Wizard
- Services =>
. Windows Image Acquisition (WIA)
+ REMOTE ACCESS
- Services =>
. Remote Access Auto Connection Manager
. Remote Access Connection Manager
. Remote Desktop Configuration
. Remote Desktop Services
. Remote Desktop Services UserMode Port Redirector
. Remote Procedure Call (RPC) Locator
. Remote Registry
. Routing and Remote Access
. Windows Remote Management (WS-Management)
+ SECURITY (Remove it only if you use an Antivirus with spyware and firewall)
- Services =>
. Windows Defender
. Windows Firewall (Breaks "Share Folder" function (Returned msg: "your folder can't be shared")
+ SHARING
- Services =>
. Application Layer Gateway
. Computer Browser
. Workstation (Breaks Computer Browser)
+ SMART CARDS
- Drivers =>
. Smart Card
- Services =>
. Certificate Propagation
. Smart Card
. Smart Card Removal Policy
- SOFTWARE INSTALLATION (*.exe, *.msi, etc...) (NOT SAFE TO REMOVE)
- Services =>
. Application Experience (Application Installation works great without)
. Application Identity
. Application Information
. COM+ Event System (Breaks SPP Notification Service)
. Program Compatibilty Assistance Service (Application Installation works great without)
. Software Protection
. SPP Notification Service
. Windows Installer (For *.msi installer and Windows Default Deatures)
- WINDOWS DEFAULT FEATURES
- Services =>
. Windows Modules Installer (For Default Features in Add or Remove Software from Control Panel)
- WINDOWS EVENT LOG
- Services =>
. Windows Event Collector
. Windows Event Log
+ WINDOWS MEDIA CENTER (Keep “Windows Media center” Default Features)
- Multimedia =>
. Windows Media Center
- Services =>
. SSDP Discovery
. Media Center Extender Service
. UPnP Device Host
. Windows Media Center Receiver Service
. Windows Media Center Scheduler Service
(. PnP-X IP Bus Enumerator)
+ WINDOWS MEDIA PLAYER (Keep “Windows Media Player” Default Features)
- Multimedia =>
. Windows Codec Packages
. Windows Media Encoders and Decoders
. Windows Media Player
- Services =>
. Windows Media Player Network Sharing Service
+ WINDOWS UPDATE
- Services =>
. Background Intelligence Transfer Service (BITS)
. COM+ Event System (Breaks BITS and SENS)
. System Event Notification Service
. Windows Update
- System =>
. Windows Cache File (winsxs)
+ WINSAT (Link to post)
- Accessories =>
. Action Center
. Disk Cleanup
- Drivers => Display =>
. Choose one for your hardware or integrate one
- Multimedia =>
. Windows Media Player (Keep “Windows Media Player” Default Features)
+ XPS (Keep “XPS Services” and “XPS Viewer” Default Features)
. XPS Document Writer
- System =>
. XPS Viewer
IV - COMPONENTS NEEDED FOR SOFTWARE
* Games
- Services =>
. Windows Error Reporting (Breaks some games like "Gears of War")
* Intel SSD Toolbox v2.0+
- Services =>
. Volume Shadow Copy (Breaks TRIM in Intel SSD Toolbox v2.0+)
* MISSING "SEND TO DESKTOP" shortcut
Just keep "Windows Mail" or add the file "SENDMAIL.DLL" to keep list
* FRAMEWORK .NET 4.0
- Network =>
. Windows Presentation Foundation Host
* Office 2010
- System =>
. Eventing Command Line Utility
* Optimus Nvidia Graphics (Hardware)
- Drivers => Graphics Drivers =>
. Intel
. Nvidia
- Drivers => System Drivers =>
. All drivers
* Virtualization Software (VirtualBox and VMware)
* For VMware =
. Intel
- Drivers => Storage Controller =
. Intel
. LSI
. Micosoft
. Scsi
* For VirtualBox =
- Drivers => Network :
. Intel
- Drivers => Storage Controller :
. Intel
. Microsoft
V - CHANGELOG =
10/18/2010 -> Browse by category
10/19/2010 -> Browse by RT7 Lite order
10/20/2010 -> Cosmetics
10/21/2010 -> My own keep list
10/22/2010 -> Services "Windows Error Reporting" (gor17981) and "Volume Shadow Copy" Added ; Cosmetics
12/01/2010 -> Cosmetics ; Section TODO
12/05/2010 -> Change Minimum Requirement : WINDOWS 7 with SP1 RC
12/07/2010 -> Version 2 of the post
HAPPY NEW YEAR 2011
01/12/2011 -> Change title of Section II
01/15/2011 -> Comment for Drivers -> Scanners -> Microsoft (Breaks Printers Support) and Integrate my LastSession.ini in the post
01/20/2011 -> Add service "WINSAT" (Jpapertowels) ; Move "Computer Browser" and "Windows Default Features" from Section III to Section II ; Cosmetics
01/21/2011 -> Reorganize Sections V and VI to integrate a new one : Need Help for Some Tests ; Cosmetics
02/17/2011 -> Add Links to other posts where you can find explanation for some Components in Section II
02/19/2011 -> I made a mistake in Section IV = Change all lastsession.ini to lastsession.INF. (Thanks to Myselfidem)
02/20/2011 -> I'll add my complete lastsession.inf (Removed Components and Tweaks) in Section IV = Configure it as you wish !!!
03/03/2011 -> Version 3 of the post
- Change Minimum Requirements to Windows 7 with SP1 RTM
- Move the section "My lastsession.inf" to the begining of the post. So if you use my lastsession you could add or remove some components for your needs with other sections
- Section III : Use a new color code to try to add (+) or remove (-) components to my Lastsession.inf
03/12/2011 -> Add in the section V (need help) : XP Mode
03/21/2011 -> My best friend, Henri COURSAGET, died : Goodbye Henri. RIP.
03/23/2011 -> Add "Credentials Manager" in Section III (Duck) ; Many little importants things added by Nguyen T (LINK)
04/07/2011 -> Add "Missing Send to Desktop shortcut" to Section IV by Nguyen T (LINK) with the great advice of akf (LINK)
05/03/2011 -> Add compatibilty to RT7 - 2.5.0+
09/18/2011 -> Update my lastsession to resolve an annoying files authorization bugs (Remove "Application Experience") ; Add "Application Experience" in "II - Never delete these files" ; Move my lastsession from Megaupload to Microsoft Skydrive
11.05.2011 -> Changed download link
Happy New Year 2012
2012.03.24 -> Add a new EXTREME lastsession to remove even more components and keep stability from Original Winterstorm2050 Lastession
2012.06.10 -> Remove Section V (Need help) and VI (ToDo), they are deprecated ; Add "Optimus Nvidia Graphics" in Section IV by Phsmu (LINK) ; Add Virtualization Software (VirtualBox and VMware) by Winterstorm2050 (LINK)
2012.06.22 -> Add in Section IV ".Net Framework 4.0" (billybully)
2012.08.10 -> Version 4.00 (Link)
IMPORTANT :
I assume there are possible errors in the list so this is why I need help to complete this post. It takes some time to test all possibilities, and if some people have tried (and verified) with success others components to keep, I'll add them into the list.
I don't have all solutions but with our community we can do something good.
Winterstorm 2050.
