STATUS :
--> v5.01 build 108 : 2012.08.27 (Changelog)
Quote
*****************************************************************************This software is just a complement to RT7-Lite.
RT7-Booster could remove more stuff that RT7-Lite could do.
So, you should customize first, your ISO with RT7-Lite and ONLY AFTER you could use RT7-Booster.
==> DO NOT use Booster as a standalone software : in this case the result is not as you expect !!!
Thanks.
REQUIREMENTS =
- Free
- OS : Windows 7 SP1 x32 or x64 (All Languages supported)
- RAM : 20 Mo minimum
- HDD : Need a partition with more than 20 Go free on your harddrive or on a partition
- Minimum Screen Resolution : 1366x76
- All Languages are supported
- Net Framework 3.5
- No Installation needed (BUT keep "D:\RT7-Booster" as directory to avoid various problems with imagex (Don't like "C:\") or 7zip (Don't like paths with spaces))
- RT7-Booster is recommended for optimizing your RT7-Lite ISO
- A good skill in using RT7 Lite is recommended
-> And don't forget, you use it at your own risk. So, in all cases, it's better to test your ISO with Virtualbox (or VMware).
OPTIMIZATION PERFORMANCE GUIDE =
Find in this section many things you could do to achieve the best performance for removing components with RT7-Booster :
- Install RT7-Booster in your fastest HDD or SSD
- Create a RamDisk (Arock Tutorial) and change the working folder in the RamDisk (Available in Booster v4.62.180+)
- Put your ISO source file in a different HDD (not partition on the same disk)
- Disable your AntiVirus
INSTRUCTIONS =
1 - Use RT7-Lite (KEEP ONLY 1 version (Basic, Premium, Ultimate,...) in your ISO)
2 - You could put RT7-Booster anywhere on your HDD (The best choice is to place your it in "D:\RT7-Booster\ISO" folder, but in all cases don't use spaces in paths or in ISO name)
3 - Launch "RT7-Booster.exe" (Try to Change Background Picture or Activate Transparency). Launch it "As Administrator" if it's not working.
4 - MOUNT : your Folder or your ISO by choosing it anywhere on your HDD
5 - Choose your Components, Tweaks, ...
6 - APPLY : your changes, you choose previously
7 - COMMIT and CREATE ISO : this create your new slim ISO, you could find it in "D:\RT7-Booster\ISO"
PS : Find all information for old RT7-Booster Version in the 2nd post
